What is this called?
Myplague797
Dec 12, 2007
Tucson, Arizona
I'm sorry, but I'm not sure if this is the right place for this question. But, I recently discorvered a leak in a hose. Now, the only problem is, I'm not sure what's the name of it specifically. Here's a picture of this, it looks to me like a hose that connects to a tubing to a water jacket. I'm not sure though.
Thanks.
I couldn't tell you what it's called, but it's just vacuum tubing. You should be able to pick it up a foot or two (and just cut to size) at NAPA, Autozone, Advance, etc. or even some hardware stores.
I'm sure someone here can tell you the size just by looking at it...
Thanks. This also carries radiator fluid any type of tubing that's specific for that? Also, I really appreciate this.
NOOOOO! That is not Vaccum hose. That is called a heater hose. It is a small section of Heater hose not vaccum hose which is not rated for high tempture exposure for long periods of time. That line runs from your t-stat housing to your heater core and to your lower radiator hose.
Hah, vacuum hose on that would lead up to some nasty stains on your block....like mine :( Damn headgasket...
