2G What is this blue black connector on the brake electrical circuit
Atuca
Supporting Member
1,145
303
Jan 6, 2007
Central Valley, California
I've included several pictures, and don't know what it does exactly.
It runs to the green wire pin 1 on connector b-06 brake switch connector. From the brake switch it runs to b-07 power distribution block, though befor hitting pin 11 of that, it shifts off to this unknown blue and black connector (plug) down the green wire and then back to a grounding block via the black.
I unplugged the connector and used the green wire's pin to wire my brake lights to the brake pedal directly (temporarily), but wondered what this plug does, and if nothing I care about for race car, can I remove it.
(connector in question is 3rd picture)
Thanks.
I would take a photo of the fsm but my phone is being quirky. I have it sitting next to me which is where I found the connector names and pin outs of the connectors I was able to identify.
I saw a giant spoon about 2 feet long in Target the other day. I thought of you Brian.
It's a resistor, B-14, for the ABS or cruise control system. In a race car, I don't imagine you would have either of those.
The black wire from that connector leads to junction connector B-08 pin 9, exits same connector pin 2, and goes to ground. Overall, it connects with the cruise ECU pin 15 and ABS ECU pin 14 as well as the stop light switch.
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
