What is the most secure way of having the EPROM socketed?
hollywood_ikr
308
6
Jan 17, 2006
el paso, Texas
I had an "expert" socket an eprom for me and he messed it up and I don't know if it is repairable.
I was lucky to find another eprom at a junk yard and now I need it socketed.
I can't afford for that to happen again. Who does the best job at socketing ecu's? Prices would also be nice to know.
thank you.
:dsm:
Blush.
The circuit traces on 2g ECUs are pretty fine and sometimes the heat from desoldering the pins can crack them. That's why using a temp controlled soldering iron is critical. However most of the time the damage seems to be caused by carelessness, some even look like a crowbar was used when they got tired of trying to get all the solder out of the holes.
It's good that you have a replacement but you should send in the damaged one too and have it looked at by someone who knows what they are doing.
I'm clearly biased but if I were needing work Dave at ECMTuning is the only other person I'd trust with my stuff.
  • For sale 2g 2G Driver Side & Manual Trans Mount with Poly Inserts
    2G Driver Side & Manual Trans Mount with Poly Inserts $70 + shipping & paypal feesYou must be...
  • For sale 2g 2G Dejon Tool Upper IC Pipes
    2G Dejon Tool Upper IC Pipes $80 + shipping & paypal fees* throttle body flange looks brand...
  • For sale 4G63 Cometic 86mm Head Gasket
    Cometic 86mm Head Gasket $70 + shipping & paypal fees.051 MLSYou must be registered to see...
  • Wanted 1g Looking for 1g interior
    Wanting to buy driver side a pillar interior (with pods preferred), both interior b pillars...
    • Walnuts
  • For sale 4G63 Ebay T3/T4 TO4E Turbo & Manifold
    Ebay T3/T4 TO4E Turbo & Manifold $100 + shipping & paypal feesYou must be registered to see...
