what is the hx40 record on straight 93octane??
cody92talon
88
May 11, 2007
Beavertown, Pennsylvania
Like the title says, does anyone know what the record is for the hx40 on straight 93 octane no meth ect.... I tried searching around but only found people on e85 or pump with meth.
I know Dave went either 10.9 or 10.7 on pump 93 with boost in the high 20's back when the built engine and turbo were first on the car.
You should be able to get deeper than that with an efficient intercooler considering Gabe went 10.71, trapped 134mph, and made 560whp with a HY35 in his full-weight 2G daily-driver on 93 octane right out of the pump. ;)
Straight 93 pump, i went 10.91 on street tires, and 10.78 with slicks! Then i switched to race fuel and never tried to go faster on pump!
Alright thanks guys. According to that 1/4 mile link above 10.42 is the record. I went [email protected]. It has a 10.5- 10.4 in it the track conditions nd weather sucked that day. I'm coming for your 9.67 record in the spring time when I get my trans done Dave. So your gonna have some friendly competiton:thumb:
Here are some pics of it
Nice times! Car looks great! That record will be smashed this spring once my car rolls out, as my new build is 600lbs lighter, better intercooler and should have more seat time to pull off better 60fts then what my 9.67 pass had! but all in all good luck on running 9s, hope to see it, and have fun!
Thanks Dave. And good luck to you too. Mine is middle weight area. It weighs 2795 without me in it.my motor is 10:1 so I could only go up to 28psi on pump. It made 460awhp on stms mustang dyno. But once I get my trans done so that I have more gear to cut her loose its going for e85 tune with 40+ psi then she should be pulling 9s.
Im trying to get 9s on my HX40 but definitly wont see it on pump or on the DSM flange :p I'm going to try and see how far i can push the .55AR BEP on 94 octane and a new 4 inch thick ETS FMIC! :p does anyne know the record on pump gas for the DSM flange .55AR for the 1/4 mile. I know there was a 653 dyno number but i dont recall seeing a time with it.
  • Wanted 6 bolt NT water pipe
    • chrisman287
