fastest e.t. on 93octane 2g
6damian6
181
Nov 26, 2002
L.I.T.H., Illinois
I was wondering what the record was for a 2g on pump gas in the 1/4?
thanks
-Damian
11.8@118
That's the fastest I can think of off the top of my head. Thats is Intusive's car. He is running a stroker motor and a 3065, 93octane!
Nos~4G63 said:
11.8@118
That's the record? I'm running 12.9's and a little lower on a small16g, granted I am using alky, but the previous owner was running around 12.7's on 93 octane.
My friend did an 11.4 @124-5 full weight,2.0,ams spec gt35r,meth inj ,magnus smim,272,link,etc,etc
He is talking pump gas only. Not with the aid of meth injection.
97TSIAWD said:
He actually didn't say that, and also it technically still is with pump. Meth injection is a mod its not running race gas.
Thank you
What about Drew's 2g? I know he is pushing like 500+hp with the green on pump gas, I don't know if he has taken it to the track but I imagine his et would be very low.
Are you referring to Dre's white 2g? I believe he was in the 400s with a green but switched to a custom 50trim to make over 500whp on 93. I have no idea if he has brought it to the track but Dre's car is beautiful.
http://www.twingles.com/ideck/
Yeah, I forgot he switched turbos. But still his hp on pump was ludacris.
I found this at the March 10 2002 update on Dre's site...
"New track results, 11.7 @ 119, all the information is at my times page, http://www.twingles.com/ideck/eclipse/times.htm, timeslip is also scanned there, and a link to the MPEG of that run there as well. Here is a quick link: http://www.twingles.com/ideck/mpg/117runsoundb.mpg
Unfortunately, this run was only at 20psi, not my dynoed 420whp. But on a good note, i'm still tuning on 93 octane. I will move on to 117+octane as soon as I build up this bottom end. "
thanks for all the replies, and yes i should have put 93octane only. The track opens up in april around here so i'll see what i can run on pump.
-Damian
Last time I went to the 1/4 mile track was in July of 2003 but the car was running 11.5's on pump gas at 21-22psi. Then after fixing some problems (AUG 2003) I had the car running 7.30's on pump gas at 22-23psi in the 1/8th mile.
Intrusive97gsx said:
Last time I went to the 1/4 was in July of 2003 but the car was running 11.5's on pump gas at 21-22psi. Then after fixing some problems (AUG 2003) I had the car running 7.30's on pump gas at 22-23psi in the 1/8th mile.
That 11.5 is great on pump, what kind of turbo were you using to hit that at 21-22psi?
I run 11.9/119 on 94octane1/4 tank(15litres) and 3 litres of 110..23psi. 11.2afr
Usually run 12.2/3 at 117 on just pump...50trim 7 bolt
  • Wanted 6 bolt NT water pipe
    • chrisman287
