what intake to run with GM MAF setup?
BOOSTIN21
413
3
Sep 22, 2003
Cedarburg, Wisconsin
i need to know what intake i should run with the GM MAF set-up dejon tool has one it's the CIP 1g-D it says it's for non-mas fuel systems and can't be used with stock mas. so does that mean that it's good for the GM MAF does it have the nipples for the wastegate solenoid the breather hose that goes to the valve cover and the other hose? i really need to know or if any one has a suggestion for my 1g's intake
Call dejon and tell them what you want. They can put the nipples on there if you ask them to.
In case you didn't find one, you can always just plug it into your stock intake. still makes a noticeable difference. boost seems to come on stronger, car pulls a bit harder, and bov is much much louder :thumb:
You can always unhook the hose that runs to the valve cover and put a filter on the end to keep anything from coming up. And about the other hose, Do a search for "charcoal canister".
http://www.taboospeedshop.com/emissions.htm
http://www.dsmtuners.com/forums/showthread.php?t=127939&highlight=charcoal+canister
cool thanks for all the help guys i wil try contacting dejon tool ASAP
