what injectors
aajj1987
199
Sep 8, 2005
ward, Arkansas
ok built 7 bolt bottom end with a 1g head and cams and intake manifold with a t60 turbo and a stealth force 355... WILL 880s be enough or should I look for different options.
You should go as big as you can afford to and still be able to control. For example, i had a 6266 on my car, got some fic 1680's. switched turbos to 6766 dbb and now im out of fuel. Time for 2150's.
Considering your built I'm assuming your on some type of tuning system right? Few people i know that are not as built as you are have already maxed out their 880s, and switched when they got tuned on e85, i would recommend upgrading soon for those big numbers =P
the bottom end is a built seven bolt I just got a eprom my friend is socketing it for me... ordered an ebay wideband gauge for use with my volkswagon wideband/stock replacement. im starting the head swap soon as my arp headbolts come in. ok ill go bigger then ill have to put it off till I can find something more comparable to my build
  • Wanted 6 bolt NT water pipe
    • chrisman287
