what does this mean "Eliminate Airflow Cap"
Just by reading it I would assume that there is a cap on how much airflow you get and it allows as much airflow as possible. Sort of like taking away a governor.
Sent from my iPhone using Tapatalk
Yes, in the stock code there is a upper bound on the airflow measured that impacts guys with big turbos. You can see when you are hitting it because the injector pulse width plateaus while the airflow per rev continues to climb. This causes the car to start running pretty lean once you hit it.
