what do you think?
You also failed. Because he is asking if it is worth buying not asking what it's worth.
If you are willing to pull the trans off and replace the flywheel then by all means it's worth buying. But do all those "Performance Parts" tell you something about the car? The car is only $1000 but could be beat to hell.
Remember when buying a car. You get what you pay for. So be ready to check everything over. Compression check, Examine oil, Tranny fluid etc etc. Check the coolant reservoir for carbon (Signs of a blown head gasket) etc etc etc. Pull TCU codes and ECU codes. Make sure there are no hidden issues that could cost you in the long run. And if it's too good to be true it usually is.
If you feel inclined to buy it please do yourself a favor and get a manual. That's #1 priority for buying ANY car if you are the DIY kinda guy.
It's a simple procedure if you have experience with cars. You can get a flywheel from a junkyard.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
