What Do You Think Of My Setup ?
ShadeTreeDSM
269
Sep 16, 2005
Fort Lauderdale, Florida
Shooting for 400 wheel horsepower on stock rebuild setup on my 1990 GSX, tell me what you think.:thumb:
Machine Work:
Block:
Getting bored .20 over
Shot peen & recondition connecting rods & topped off with ARP hardware
Align hone crankshaft bores for installation ARP Main Studs
Crankshaft miked & polished
Cylinder Head:
Hot tanked & checked for any bent valves or leaking seals
Block:
Brand new Topline :shhh: .20 over 8.0:1 pistons & new rings
ACL rod & main bearings
Balance shaft eliminator kit
ARP head studs, main studs, & rod bolts
Cometic head gasket
Cylinder Head:
Gasket matched port & polish
HKS 272 intake & exhaust camshafts
HKS valvetrain
Fidanza cam gears
Fuel & Ignition:
Siemens Deka 870 cc/min injectors
Greddy Emanage
MSD DIS-2 Ignition
NGK BPR7ES Plugs
MSD Wires
Turbo & Misc:
T3/T04E 57 trim
DNP T3/T4 tubular manifold
Tial 40mm wastegate
3.00" turbo back exhaust w/ magnaflow muffler.
Jm Fabrications sheet metal intake manifold
HKS SSQ Bov
Precision FMIC 31.5"x10 5/8"x3.5"
3.00" piping (from FMIC to throttle body)
2.50" piping hot side (from turbo to FMIC)
Trans:
ACT 2100 clutch
sooooo yeaaa
First thing to change is the clutch. If you do make 400hp or even 300 that clutch wont last long. I would get bigger injectors also. Those can be maxed out with a 50 trim. And you will save money later if you decide to use a bigger turbo. You don't need the cam gears. 2.5" intercooler piping all the way is better for your goal. 3" will decrease spool and I know two 600+hp talons with 2.5" piping. And I would use dsmlink instead of the emanage.
Get DSMlink Instead of the Greddy Emanage/MSD Ignition
Run 2.5 in ic piping all the way
Forget the cam gears and instead of getting HKS 272 combo, go a cheaper but proven route and get some BC 272's or 280's and bc valve train. That will save you some money but keep the performance gains.
As mentioned above, you may want to look into a better clutch setup.
If this is your daily driver, you may want to think about a different exhaust manifold as I have heard a lot about DNP's tubular ones craking...
Just my .02
-Kevin-
I agree with them ^^ they make some good points. Other than that the list looks great.
