What do stock injectors look like for 2nd gen motor
tundra2000
49
Jan 7, 2011
pelican rapids, Minnesota
I got 2 sets of stock fuel injectors, one set of injectors are full black and the other set has pink tops were the fuel injectors wires connect to the injector, which one is stock injectors for 2nd gen turbo motor? Sorry if their not much info to this.
pink tops sound like evo8/9 injectors to me, so 560's
above is right though, the black injectors are your stock ones.
ok thanks, I got a problem though the 2g fuel rail and injectors are on my car now but the fuel pressure regulator doesn't seem to close when i turn the car on fuel keeps spraying out the regulator, is the regulator stuck open and would i be able to clean it?
when you say its spraying out of the regulator, do you mean its spraying out into the atmosphere? or spraying out into the return line?
if theres fuel leaking out into the engine bay you need to make sure the return line is connected and that there are no leaks. if the regulator is never closing it might be a bad regulator. do you have a stock fuel pump?
yeah i think the fuel pump is stock, but when i turn the key on and the fuel pump primes it keeps going and the regulator doesn't seem to close it just goes though the return line.
