What are these holes for?
WatchItExplode
314
11
Jan 4, 2005
Mesa, Arizona
Basically I'm an idiot and forgot what these holes in my block are for during the process of installing my new engine. :D Here's a picture of my old engine, I circled the holes in question in green, and the ones I know in red. Sorry for the poor quality, I can provide clearer ones if necessary. I labeled the knock sensor, intake mani support bracket, and air compressor bracket.
I was also curious as to what this hose coming out of my firewall is for...
Just to name a few things for the holes.....carrier bearing for the axle, a/c bracket, and intake support bracket.
On my 94 7 bolt, but it seems the same for my 6 bolters........
Upper right-not used
Upper left-not used
Bottom- used in conjunction with the right lower A/C mount to hold Carrier bearing for left front axle shaft
Remember to install bolts in those unused holes so that I can beat you in a race by .00001 seconds! :sneaky:
Hope that helps.
Hey-I hope you didn't pay extra for all that extra black paint globed in the middle of your engine!
Finally a reply, thank you! And no wonder that bottom right AC bracket bolt wouldn't go all the way back in...haha.
As for that big glob, I don't have a clue what it is and I don't care, because that's my old engine :thumb:
I hate to bump this thread all over again, but I do actually have a bolt that goes in that upper left hole. See, while transfering everything from my old engine to the new longblock, I took a bolt out of said hole and stuck it into the corresponding hole of the new engine. I'm pretty sure I didn't mix anything up. So are you sure it isn't used?
