What are the seat track measurements?
psleclipse
Nov 16, 2010
Port St Lucie, Florida
Does anyone have the measurements from bolt hole to bolt hole front to back and side to side?
I don't have an eclipse any more, but my nephew is getting one from his dad and wanted to surprise him with some custom seats
(I did search but didn't find them)
thanks in advance
I see no one has answered this yet so I will ask which version Eclipse is it? I have 93, 94 and 99's I can get you measurements from.
What you're doing is great but just because a seat fits the track hardly means it will even come close to bolting down into the car safely. Common problems with putting race seats into a 2g are headroom clearance as well as door panel clearance...
There are a few seats that bolt in and can get away with sliders, etc. but you wouldn't need the measurements of the rails to use them because you can buy the seat brackets aftermarket using Wedge Engineering or Planted Technology.
thanks, but i was able to get the seat measurements already, I just need the measurements from the center of each mounting bolt hole
If you are asking for the hole pattern in the chassis, it's not a planar rectangular pattern. If i remember correctly the 2 front holes are oriented ~45degrees fwd, and the rear holes are not even on the same plane.
Something like this:
