What are stock fuel injectors in a 96 N/T ???
speed127
85
Nov 1, 2005
Philly, Pennsylvania
I have heard that turbo injectors are stock 450 but having a N/T in which I plan on adding a turbo I was wondering how big they are? 300? 250? Will they be able to handle 8-10 psi as a daily driver? Thanx guys :thumb:
I am not sure what exact size they are. with a fmu they will be able to handle close to 10 psi. if you search in the nt bolt on section you will find your answer.
they are 235cc's and yes they can handle 10 psi if you use a 255 lph fuel pump and a fmu i run mine at 60 psi at idle and 2 psi increase per psi of boost :dsm:
wouldnt it just have been easier to buy a set of larger injectors? why run you inj's a 130% duty cycle? i think you would be alright but look into getting some larger inj's pretty soon after you get it turbo'd
RS-T ..... you only had them at 2:1 when in boost? I have been doing some reading and everywhere I look I see that you should raise it like 10:1. Now I think thats too high, figure 45psi at idle + WOT + 100psi if I have 10 pounds of boost.. thats just WAY too much. SO WTF
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
