What am I getting myself into??
my98GST
1,045
21
Jun 1, 2005
Cleveland, Tennessee
I recieved my skunk2 coilovers today and I was planning to install them tomarow along with my inner and outer tie rods on the driver side since they are both completely shot from where i slid into a concrete rise when it started to rain a few months ago.
How hard is it to install the shocks with coilovers? I was planning on useing the stock shocks for now until i can save up a little more money and go with the AGX's or Tokico Illumina's.
The reason for posting this is i've never done anything with coilovers and if its going to be a royal pain in the ass to install the stockers and then in a month or two have to repull them and install the new ones then i may just hold off and sell a few things and get some more $$$. Please rate the install of shocks and coilovers on a 1-10 scale.
Thanks a billion. Oh yeah this is going to be on a 2g GST
http://www.vfaq.com/mods/GCkit-2G.html
Theres the VFAQ how-to about GC coilovers, should be somewhat similar for your skunks. Just remember that with lower suspension bolts they can be a bi*** to get loose, but with that in mind its really not a bad install. Keep in mind you will most likely blow your stock shocks because of the higher spring rate. If it was me, I'd want to do it all at once (I personally hate disassembling the shock assembly to change the springs and all), but its up to you I guess. Good luck!
I would also recommend doing it all at once if you can...Ive done it 4 times on my car and each time i hate it more and more
:thumb: . I absolutly hate suspension work. Screw coilovers and get some decent springs. They really are a pain in the ass and somewhat useless (as after you have your alignment done and your camber kits adjusted) it's best to leave it at that height, besides you will hate the thought of having to adjust it.
