tsilover
- 254
- 0
- Oct 20, 2002
I have a problem with my car. Last night when i tried to start the car, it wouldn't stay running, it would run 4 like 5 seconds real rough and then it would die. This morning i tried to start it, and it ran first time. I was like
but i drove it today and all was well. Tonight i went to start and it did the same thing.
Some other things that has happened. On friday i was picking up someone for work and my car died in front of her house (morning). It started like 15 minutes later. It drove fine and then coming home, it broke down. Luckily it started after like 15 minutes and drove fine home.
I just had a new motor installed with an act 2600, when the car does start it clicks when the clutch pedal is pressed.
I wrote this as i thought of it. I was thinking some sort of fluid is reacting to the drop in temp and humidity at night. Any help would be appreciated. Thanks guys.
but i drove it today and all was well. Tonight i went to start and it did the same thing.Some other things that has happened. On friday i was picking up someone for work and my car died in front of her house (morning). It started like 15 minutes later. It drove fine and then coming home, it broke down. Luckily it started after like 15 minutes and drove fine home.
When battery drains, it's dead. You need to charge it before you can start again.
