Weird oil leak!!
boostyGST
325
Aug 11, 2004
Flintstone, Maryland
hey guys ..... had a oil leak ..... thought it was the oil return line ..... replaced it and new gaskets .... does not leak oil anymore ..... still drips oil but not as much ....tightened the oil pan bolts, thought that was the problem...they were really lose ..... but still drips a little oil but not as much ..... what is under there that would leak oil that i am not aware of ..... help me out ,
IF I REPLACED THE OIL PAN GASKET DO YOU THINK THAT WOULD SOLVE MY PROB...
THKS YOU .TYLER
Clean all of the oil off from the bottom of the pan, the oil return line and the oil filter housing., then check to see where the oil is coming from. Once you know where the oil is coming from then you can proceed form there. Dont' spend any money you dont hav eto
change your oil and use some thin based oil, then look for the leak bet u, u will find it. Dont do it on the driveway, I learned from my mistakes
