Weird Noise At High RPM
ECLIPSE95
430
Nov 13, 2002
Missoula, Montana
1995 TSi Awd...first of all i have no clue why this is happening...the car studders once it reaches high RPM's in any gear..its around 5-6k and I heard a weird noise like a metal scraping noise..any ideas??
does it do that when your'e in neutral too?
Where is the noise coming from? Uner the valve cover? timing belt?
If its under the valve cover and only makes the noise when you're revving then .. it might be rod knock.. but just to be sure drop your oil pan and check for metal in there
good luck
i just replaced my clutch and a new TOB and its seems like it is comming from the engine or the tranny..but it makes my RPMs go down..when it happens so it loses power and kinda chugs alittle..I havent tried it in netural yet..but I do know it happens when I really get on it...
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
