Weird Grinding/Rubbing Noise
InjenTalon96
242
Oct 12, 2003
Plainville, Connecticut
ok if i keep my wheel strait everything is cool, its untill ill take a left turn or is i just turn it a little bit, but if i turn it to the right theres no noise, i thought maybe there was sumthing rubbing my rim but that turned out to be wrong, i cant find out what the noise is, ive had it on a lift and turned the tired but i dont here the noise then....now say if i turn the wheel a little bit left it will be a whobble grind noise....like ch..ch..ch..ch..ch..ch. then if i turn it more it will just be a continious noise....what could it be???
no cv joint....i know its not that they are all new....but i i already know my bearing are shot, but this noise i think mite be coming from the brakes...i duno
One reason why brakes can rub when the car is turning a particular direction is because the wheel bearing is shot.
Driving around with bad wheel bearings is akin to having wild, unprotected sex. Fun, noisy, and really unintelligent.
- Jtoby
- Jtoby
well thats a good way to put it, so this is a dumb question in all but what would happen if i keep driving this like that...
The odds of you losing control of the car and killing someone is greatly increased when you have a bad wheel bearing. It can seize or break.
- Jtoby
EclpzLvr97 said:
First check that all your lugnuts are still there and tight.... if that's good....then, what he said.
Let us know what you find. I'm curious.
Ditto, I had a similar noise - turned out the lugnuts on my wheel were noise. :thumbdown:
im actually having the same problem with my car, where if i turn it right theres no noise, but if its left, i get a rubbing noise too.. so i guess i will go out now and inspect :cool: ..
do you have lowering springs?
my lowering springs rub with the cv boot when i make turns :shhh:
ok well i still cant find it, i think it mite be something rubbing in my brakes, it sounds like when the brakes are low and the clip hits....but its not the clip, any suggestions
