Weird Fuel pump issue
gst noob
100
Jul 11, 2012
Waterloo, Iowa
So I'm working on a buddies 2g gst and it turns over good and has spark but no fuel so first I took off the fuel rail to see if the injectors were squirting they wernt.
Next I took the lines off at the pump and turned it over and no fuel came out of he assembly. I can hear the pump whining in the tank I know it's turning on so I take it out and mess with it can't figure any thing out so I swap it with a pump I know works still the same problem the pump is turning on but not pumping.
I took the pump and wired it up with out the assembly and dropped it in, turned the car over and I can see the pump torquing in the tank and its making noise both pumps do this but no fluid come out. Iv also swapped out relays. Thanks for any help
It's defenetly not out of gas :toobad: and theirs plenty of gas in the tank. When I swapped wires the pump wouldent even turn on. And I hard wired it and still nothing. I been switching between 2 pumps I know work.
The fuel filter has nothing to do with it gas wont even come out of the pump and the bag on the pump is just fine. It's a 96 with a 1g cas
Are you getting power to your injectors? Were you cranking it over when you were trying to see if fuel was coming out? If you aren't getting fuel you could see if it is the MFI relay.
This right here should tell you the pump shit the bed.
