m1nd64m3
- 715
- 22
- Sep 17, 2003
Chicagoland area,
Illinois
So my car is throwing two codes, one for the tps sensor and another for the park neutral switch. The car is a 98 gst auto, so the park neutral switch is located on the trans itself.
This is where it gets weird, from what I gather on the park neutral switch from searching here is that if it is faulty then the car won't even start, but it starts up fine.
For the tps sensor, it checks out fine on the s-afc, goes 0-100% like it should. Only cause for concern is that the tps will sometimes read between 1-2% after startup (without pressing the throttle), not sure if this is normal or not.
Now the car itself is acting kind of funky lately. First off the car will downshift into first hard enough to chirp the tires, but it only does this after first starting the car and putting it into drive. It seems like it's holding onto 2nd or 3rd and when it finally shifts it may downshift hard if I'm accelerating, or it will shift into the next gear if I'm babying it and go real easy on the gas. This all started after I pulled the engine/transmission to fix some other unrelated things. And it will do this every time after starting it, even if it's shut off and turned back on. I thought the problem was related to my mounts being shot, but I just filled them and it did it again once out of the 4 times I've started it since, so I believe the problem is still there but the mounts were making it worse.
The car is also idling high this past day since I have filled my mounts. It is idling between 1500 and 2000 so I believe it could be related to the tps and park neutral switch some how. I also disconnected the isc to see if that would cause anything but it did nothing so I suspect the isc may be bad as well.
I already see how to test the tps sensor, and what I'm looking for looks to be the continuity between the 3 and 4 terminals to test for the idle switch.
I am totally unsure as to how to test the park neutral switch, I can't find anything on it regarding automatics.
I also wonder if my ecu could be causing this, I've had problems with previous alternators having bad voltage regulators so the car would regularly see 14.5-15.1 volts, i wonder if that could cause the caps to leak? And another ecu related thing is that I am able to pass emissions with none of the emissions solenoid's vacuum lines hooked up (although they are still connected to the wire harness), no egr installed, and no cat, but it never throws a code and it's been this way for many years. I do have another ecu with ecmlink v3 on it ready to go in but I wanted to pass emissions first before I start messing with ecmlink.
Can anyone shed some light on this? Looking for some pointers or some advice.
