General Weird consistent knock when idling in hot
TSiRocker
56
Dec 6, 2004
Texas, Central America
I notice on my S-AFC2, the knock reading when my engine has warmed up and idling is high., around 18, sometimes around 23.
Could it be the wrong use of spark plugs? I suspect that might be the cause as I just changed them recently.
The gap is 1.1mm. Could the wrong gap give strange knocking when idling?
The knock display on the safc2 isnt accurate. You need a logger to see how much knock you are getting.
I don't have a proper logger but from what I can tell from my own feelings, the engine timing is pulling real hard when engaging from first gear....as if the engine has no power to push the car.
I took that as a sign of the ECU detecting too much knock and retarding the timing too much?
You can totally ignore the knock reading from the SAFC2.
It is sooo far off it isn't funny!
I have tested this by comparing it to the readings on my logger.
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
  • For sale 1g 1g BR upper intercooler pipe. Stainless Steel
    1g upper pipe. Early BR. 2.25 inch Stainless. Bead Rolled ends. BOV flange is gone...
  • For sale Anyone interested in brembo front brakes from a evo x?
    Hey guys I happened to come across evo x brembos that work great for a good price !
    • SheNeverRuns
