TranceNRG
- 43
- 2
- Nov 13, 2005
Detroit,
Michigan
Weak spark for #1 and #3
Swapped the following, Coil, Transistor pack, ECU, Cas, Plug Wires, Plugs, made sure all ground were very good still nothing.
I tried to put a timing light on #1 didnt light up same for #3 but lights up for cylinders #2,#4.
If I disconnect #2 or #4 with engine running then #1 or #3 will get strong spark.
I need serious help with this.
The car runs, has a high rpm misfire.
