V8KLR
- 81
- 0
- Nov 22, 2008
Johnson City,
Tennessee
I'm beggining to think I have a n/t with a turbo on it. Are there anyways to tell for sure?
On the VIN number for your '91: Look for the letter "U" meaning that the factory installed the turbo for you. If you got an "R" in the VIN, it was definitely a NT (and you wouldn't have the turbo boost gauge in the tach area...duh..) - just the normal 4G63 with the standard gauge set.
If you got a "T" in that VIN, you had a 1.8 in that thing that was made up to the 4G63.
1993 the number's changed.
"B" - 4G37
"E" - 4G63 NT
"F" - 4G63 Turbo
2G's
"Y" - 420A NT
"F" - 4G63 Turbo
"G" - 4G64 Spyder 2.4L
A NT tranny... F5M33's be the turbo tranny.f5M22
Christ I'm getting old...you can see that detail in the avatar? Looks to me like stock rubber pipes and such...If thats the pic of the car in your avitar, someones been fumbling around in there doing something.... LOok at your pipes, and your intake.....
I have a Talon TSI AWD, and the Etching on the block says 4G63, the DSM Tag on the firewall says 4G63. Non have a T.
Yes you can do that plan. I strongly suggest it. One good thing is that with a good track tune, you will make quite a bit more power with the higher compression. DEFINATELY get a logger. You MUST keep an eye on knock.
