waterpump? coolant leak
Wil_OwnU
33
Nov 13, 2011
louisville, Kentucky
OK my car started leaking water out what seems to be the bottom of the water pump is it possible that the gasket went out I know there's a weep hole is that the only way to tell the pump is bad?
Thank you for your help
Looks like its time for a wp change if its leaking in that area, and a full timing belt job while your there
its not that bad a few hours and your done.
Only thing that sucks is I just changed timing belt ab 2 k ago all bearings and everything should have changed wp
Right I guess I ma take the plunge again I feel like I can change timing belt with my eyes closed had to redo it 2 times last time.But thanks for all the help guys
