water leaking through speaker grills
PlanZero
1,516
267
Aug 13, 2013
Easton, Pennsylvania
I've had this problem on 3 dsms now. When it rains or I go through the carwash, water trickles from the bottom of the door panel and through the bottom of the speaker grills. I tried putting thick plastic behind the speaker mounts to prevent speaker damage, similar to the plastic all over the door, but then I hear it vibrating from the speakers. I realize the problem lies in the weatherstrip seal that runs along the bottom of the window on the outside. I can hear it trickling down inside the doors in the carwash. Does anyone have a part # for this?
It's insane. I got the #. It's $88 for one! I don't understand how the water is diverted to wind up at the speaker grill instead of the drains. I've examined this many times with the panel off and I just can't find a solution, except to replace that strip. I'm gonna try one from the junkyard first, and maybe heat it first so I can bend it so it's more flush to the window.
Ya it's really the only place you'll ever find a new piece like that. Junkyard is always a good option cuz factory price is crazy. But there should be this plastic covering on both sides of the doors attached with a thick nasty black goo and some times people will rip that out and the goo won't seal back up perfectly Sometimes.
