Want to do a boost leak test. But have a cracked exhaust housing
So if I do one won't it just leak out the cracks in the exhaust housing?
You are pressure testing the intake, not the exhaust. :rolleyes:
But you are correct when you say that some of the boost will leak out the exhaust valves and into the exhaust manifold. But that amount of pressure is insignificant and you should still be perfectly able to pressure test your pipes.
