Walbro fuel pump rebuild?
allezgrand
85
Dec 11, 2003
Boulder, Colorado
I could have sworn I've heard this eluded to somewhere but I can't find it, so before I tear into it, I wanted to ask, can the Walbro 255 be rebuilt? If so what parts are required? Just o-rings if it's functioning but letting the pressure drop too low?
My car's brief fuel history:
I bought it from somebody who didn't set it up well. She put a Walbro 255 in and a DSMLink V3, but she never turned on any of the settings for the FPR in DSMLink. I installed an AFPR, checked the pressure and found it was nearly 75 psi. I turned it down to 40 psi, tuned it, and found that my wideband was quickly increasing (diverging from the estimated AFR) under load and the boost was creeping. I retarded timing enough to tune out all the knock and still had AFR problems and hesitation. When I adjusted the AFPR as low as it would go, pressure dropped to about 20 psi, leading me to believe that I have a fuel pump that is no longer functioning well - hence my question.
Thanks ahead of time for the help!
Chill out. The site kept returning errors from heavy traffic, so I pressed reload and it posted it 4 times, then returned more errors when I tried to delete. Either be helpful or don't reply.
They are sealed and cost 69 bucks for a new one with a warranty. I would think that one would just trash the old one. Even if it was repairable, it's most likely not worth the effort.
estoyaqui30, thank you. I will look around for this deal you're talking about. Cheapest I found them was $99 so far.
Check the o ring where the pump seals to the sending unit.
Thank you! I think that was the one I had heard of.... That's in tank then, correct? And is it replaceable if it's bad? Any idea where I could get a new one?
Yes it is in the tank. Where the pump fits into the housing there is a big fat o ring in there. I would check the dealership for a new one.
