UVaJester
- 219
- 0
- Jun 14, 2003
Virginia Beach,
Virginia
I just installed a Walbro 255hp and 750cc injectors... After installing everything and starting the engine, I notice at idle if I put foot on the brake the engine starts to sound like it is under heavy load... ( the belts whine a little, etc... similar to when you a/c turns on when your at idle..) If I raise the rpm's by stepping on the gas, the strain noise goes anyway... I find it hard to believe, but does the pump really draw that much more from the alternator/engine..???
Jester
Jester
