vrsf fmic install help
i just remove the power steering cooler and if you look real careful you will see a way to remove it without buying any new line. You just flip one of the lines on the reservoir to the return. Also the lower intercooler pipe comes very close to the alternator so be careful it is not rubbing.
That videos dosent really help and I have 1g and and I figured out where to cut what did you cut with I have angle grinder I thinks that's too big and could I just put the powersteering line behind the hood hatchet
Here are some of my old GST
does any one have pics before you put your fmic on and can show me where to cut and how to move the powersteering lines
you dont cut them, just reroute from the ps res.
