VRSF fmic 1g fitment
brandon19761
Jan 25, 2005
idaho falls, Idaho
Hello. Has anyone else gotten a core that the piping wasn't right on? Mine seems to be off a good 3/4" on the drivers side pointing in towards the radiator. I remember reading about someone else having this issue and they were sent another core that fit... I don't think I want to trim the whole inside of the radiator support to try and make it work when you shouldn't have too... I have emailed vrsf about the issue. Awaiting response.
PS.. I know the PS cooler has to go I was just eyeballing where I was going to need to cut real quick to find the drivers side way off....
You need to widen those openings. I would feed that side in first and then fit the straight side in after. I think mine might have been similar but it fit fine. The radiator fits really REALLY snug between the two pipes with the ac line very close in the mix as well.
