VRS Exhaust with EvoIII o2 housing
Chucker88
Jul 23, 2008
Winnipeg,
Will the 3" VRS turbo back exhaust system bolt right up to the EvoIII o2 housing?? Or did you have to tweak it a bit to make it fit? Do the flanges meet as well? Any help would be great, Thanks.
Since it's more angled, you might have to tweak it a bit for your downpipe to not come in contact with your transfer case. Otherwise it bolts right up.
This subject is been beaten to death. It doesn't fit well and puts stress on the DP. Some cases doesn't fit at all. There is a solution though.Forget the fact, that I have 1G. When I ordered my exhaust directly from VRS, they had the flanges on the DP loose by my request, so I had to fit everything and get them welded then, for a perfect fit.
ah ic. well i think i'm gonna go with the VRS anyways, and if it doesn't fit properly, i'll just do the adjusting. thanks for the help
