Vpc help!!!!!!!!!
spooledu1st
91
Jul 8, 2003
TK, New Jersey
Hey guys Im trying to help a freind out that is running a vpc in his supra. Im just trying to get an idea of what dose what so I can try to lean it out. The car is running pig rich and sputtering the gcc is all zeroed out. But I dont really know how to lean it out. If someone can point me in the right direction it would be very appriciated. THANKS ALOT :dsm:
Err... if you don't know hoe yo lean a car out with a GCC and a VPC, you probably should not try to tune it.
You want less fuel, so you need to turn the knob somewhere less than zero.
I was hopping you would reply Kyle thank you. I just came back from a run and I have the gain at -12 still pig rich and all the gcc leaned out also. Fuel pressure is at 45psi with vacume connected. Egts are around 600c after turbo. I was think that I should try to lower fuel pressure a little more because the car is running a tad better. Could you tell me what op output dose on the vpc. Thank you again for your help. :)
That fuel pressure seems a little high, I would try turning it down.
Are you using a wideband or something for this? If you're just tuning blind, stop now.
Thanks for your help and I know this is not a supra site. I just never used a vpc and needed a little help. But figured it all out.
