mr D
- 0
- Jan 8, 2005
Holland,
Europe
Well i have a few problems. I am new to this forum but certanly not a rookie
Have a 97 Ecipse with a 6 bolt swap and the whole engine was rebuild. There is a Garret GT10 ( hybrid ) and lots of HKS stuff etc. It produces 400+ whp ( or at least it should when everything is setup right. )
Have FWD but the Quaife diff helps wonderfully and i love the machine. You can check it out here.
http://www.cardomain.com/memberpage/486477
Now that the introduction is done i want to ask if someone had the same problems as i have.
First my engine build. I have 550 cc injectors with the HKS VPC. The VPC has a car and injector specific chip. That chip can be bought with a max setting of 550. Is this correct or does anybody know if there is a 660 chip. I think my injectors are too small. Or can i buy the 660 injectors and install them with the 550 chip. I have a VPC so can correct any fuel differences. Will the setup work this way too or can the chip not be fooled.
When i rev the engine up it jutters very fast. It cant make any power when it does that but my wideband tell me it is not lean ( 10,8 ) so that puzzles me. But that only happens when i activate the boost controller. When it is off and i run stock boost ( 0.76 bar ) ther eis no problem and the engine revs like a sunshine all the way up to the limiter. But turning the Apexi on ( AVCR ) and setting it only at .8 makes it brrrrrrrrrrr.
Could it be that the settings are not right an the boost controller. What does the duty cycle do ? I have read the instructions but am not getting any wiser ( i am dumb
That Brrrrrrrr makes me wonder if the injectors arent too small. But turning it only at .8 ???
Than the TPS. On the VPC i can see the TPS from 0 to 100%. When the engine is hot it stalls at 0%. Than when i stop the car and keep the gas pedal down it starts to climp up from 0 to 1 than 2 than 3 ???? what the.... is that. I have changed the wiring to the TPS and checked the connections. Even removed the wiring and soldered the three cables directly the the sensor but without any luck. It seems be be less faulty but still it has to be 100% ok otherwise tunig will be impossible.
Lots and lots of questions but i would be very happy if only one gets awnsered right. I hope someone can help me out here.
Thank you
)That Brrrrrrrr makes me wonder if the injectors arent too small. But turning it only at .8 ???
Thank you
