Xenocide
- 37
- 0
- Sep 2, 2004
Madison,
Wisconsin
Compression:
Cylinder 1: 200
Cylinder 2: 200
Cylinder 3: 200
Cylinder 4: 200
(this is a brand new compression test guage I just picked up today - I have no clue why it's so high and why it looks "better than good.") I just popped it in each cylinder and cranked the car over w/ the throttle open.
Leakdown:
Cylinder 1: 8% leakdown; Air leaks out valve cover when the oil cap is off
Cylinder 2: 100% leakdown; Air leaks out of the exhaust
Cylinder 3: 8% leakdown; Air leaks out valve cover when the oil cap is off and appears to leak into cylinder 4 a little bit as well.
Cylinder 4. 100% leakdown; Air leaks out cylinder 3 and intake. If I plug cylinder 3 it leaks out the intake even stronger.
Then engine that is in the car is a JDM "drop in" that was put in about 60,000 miles ago. It was an automatic (TD04 housing and 390cc injectors etc.) The car still runs and idles pretty good; I get about 25mpg average. It has a knock issue; it gets quite bad knock (10-20+) in any heavy boost situation or if I have to "lug" it at all (for example going up a hill at any RPM less than 3000 etc.)
I'm ready to boost the power a little but and have a budget of about $1500 (though it could be stretched a little.) I have a spare head w/ cams lifters etc. and a rusty shortblock that I can use as cores or replacements (the head appears good enough to bolt on if need be.) My goal for the car is to keep it as a daily driver but one with quite a bit more power. In a perfect world I'd like to build a stroker (2.3 or 2.4) but that likely wouldn't fit in the budget. I can buy JDM engines locally for about $1200 but if I knew my head or block were good I would rather throw a stage 1 or 2 head or block together with what I have. As for mods I have a big 16g and as soon as the engine is finished I have a 255 pump, 780 cc injectors, an Eprom with a dsmchips.com chip, cyclone intake, and an AFPR to install.
My question is; what the frick is up with that compression and the leakdown results; how can I have compression higher than stock that is even across the board and yet very bad leakdown? Is the headgasket blown between cylinders 3 and 4 to cause the air to leak between them? Is my knock likely from 2 good cylinders and 2 with major issues? And based on the results of these tests; would just go for a new block or head, or an entire "new" JDM engine?
Cylinder 1: 200
Cylinder 2: 200
Cylinder 3: 200
Cylinder 4: 200
Leakdown:
