2G vehicle speed sensor wiring ID
kidtsi
1,417
17
Feb 17, 2009
Laredo, Texas
I have a 95 gsx my vss connector have 3 wires
yellow (ecu)
black
black/white stripe
I know the yellow one goes to the ecu but what about the black and black/white stripe? Which one is ground and which one is power? Do they connect to the ecu also?
If you just checked the FSM you'd already know the answer.
yellow (ecu)
black (ground)
black/white stripe (Ignition switch IG1 - 12v power)
Don't have the FSM, try using Google. I found many links.
Yeah but where exactly the ground goes to the chassis or ecu? I think i have a bad ground and i wanted to test it by splicing a ground and connect it to the chassis to make sure it was the ground before taking the harness out.
