Vacuum Lines
mindset
1,853
7
Jan 3, 2009
Brunswick, Ohio
Ok, before you post the Taboo Vacuum Line diagram, stop. I've looked at it and I'm confused.
I have the red line going to the FPR.
The yellow going to the IM.
Is that the correct position? According to other pictures, the FPS has a cap on the rear that can come off, but mine is in the wrong position... or is that set up right?
I don't know where the blue vacuum line goes too, because I cannot find the T that comes off the Evaporation Emissions Canister... I believe that is the Purge Solenoid but it has that cap I was talking about above so I'm confused again. Where is that vacuum line supposed to go?
The green one I have going across the engine bay and, like the diagram said, T-ing into the "R" Vacuum line coming off the Purge Control Valve. Is that correct?
<a href="http://tinypic.com" target="_blank"><img src="http://i48.tinypic.com/fx3x4m.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
