2G Vacuum lines
bmw335ikt
228
16
Sep 23, 2015
Crown Point, Indiana
Hello I'm running my vacuum lines and want to make sure this is how you do them
I have the charcoal canister removed and have the evap blocked off
I have one line from my bov to the intake manifold. And have the p, e, a ports caped on the intake manifold. I also have the afpr and boost gauge ran on a t for the intake manifold
And now I have a tial wastegate with a punishment racing recirculated o2 hosing. And I am running the aem tru boost
Do I just install the vacuum lines just how the manual says from aem
Like this
And is that all the vacuum lines I need?
Thank you
Can someone help me out with what vac lines are what... I need to get the evap system working again. The canister is there but the smaller vac line that coneccts to the white nipple is gone need to know where i should start. First time dsm owner looking for guidence. It also has the egr delete i believe.
Check if you still have an egr valve it looks like it's been removed
I believe it has so id need to re install both for proper emissios control? I live in colorado and the inspector said my rear o2 has a constant 20mv reading suggested i replace the cat and adjust the fuel trim. But im assuming its because i have none of those installed? Failed bad nox and co are off the charts.
