Vacuum Gauge Needle Vibrates At Idle
DSM AWD TSI
60
Apr 14, 2009
San Diego, California
Hey guys,
My aftermarket boost/vacuum gauge (mechanical) needle jumps/vibrates at idle like it's trying to switch between -7 and -18 hg vacuum so fast that the needle can't move that fast and it just vibrates between -11 and -13 vacuum so fast the tip of it blurs. If I push on the throttle a bit, it will smooth out and goes as low as -20 and is smooth throughout the rest of the vacuum/boost areas. Could it still be a vacuum leak even though its smooth in non idle vacuum? Also, the car idles relatively smoothly, with a little engine vibration but that's probably from the not-so-great condition of the motor mounts. Any input on what to check or what to do about it is greatly appreciated! Thanks.
I T-d it off of the vacuum line to the fuel pressure regulator. Sorry, I meant to put that in the question part but forgot, can't remember so much info at once :barf:
