Vac/Boost Leak HELP!
missionx96x
136
Jan 30, 2006
Jackson, New Jersey
I seem to have a vac/boost leak according to my dsmlink log. i just went over all of my t bolts and clamped them down hard. heres my question though. did i miss anything else? i have my bov connected to the intake manifold. Then i have my afpr T'd with my map sensor and the intake manifold. Emissions have been removed from my car so the nipples on the TB are capped off except for one which im using for my boost gauge. Is there anything i missed anywhere?
Instead of second guessing yourself for hours, take 10 minutes, pressurize your system, and see how well it holds. Something obvious you will hear. Use soapy water to detect less obvious. Good luck.
