Vac/Boost Gauge help
bdavis90
Dec 1, 2010
janesville, Wisconsin
So i bought an Autometer Phantom Series Vac/Boost gauge and i was wondering where i hook the t-fitting up to, Thanks.
The most common spot is to T into the vac line going to the FPR.
Not my picture...just one i found using google in .05 seconds :D
Kyle
^ +1 Putting it there will give you the most accurate reading because it is right in the center of the intake.
edit: that picture doesnot show the fuel pressure solenoid, if you still run a FP solenoid place the fitting between the manifold and the solenoid.
