using t-25 oil and water lines on a 16g
joe sobo
846
Dec 30, 2007
stuart, Virginia
i have a 2g with stock t-25, and money is tight right now, so i am trying to reuse my stock lines on the 16g. i have searched to no avail.
can someone post a link on how to use the t-25 lines on a 144b/16g thanks in advenced
It's been on the VFAQ for several years now.
16G and RRE Do-it-yourself hacker/tweaker kit on a 2G
It is HIGHLY recommended to replace the oil feed line, at the very least. The drain line needs it's flange bolt holes slotted to fit the 16g oil drain flange. The water lines need to be swapped and tweaked.
how do i get to it? i searched through the vfaq, and the one you just linked me to is not on there
nonetheless, thank you very much
Yesss and you should...it has a built in "restriction." Running the turbo from the OFH, IMO is a bad idea, i did and my turbo died shortly I suggest everyone gets the 1g oil feed from the head if they are doing a 14b/16g install.
