Using non-turbo pistons in a TSI? Passable, Bad, or Very Bad?
madcows
Nov 19, 2012
Sterling Height, Michigan
Ok, I know this probably sounds ridiculous, and in reality probably is, but I'm going to ask it anyway in the hopes I get an informative reply instead of just being called an idiot. Here it goes..
So I just got my block back from the machine shop where it was bored over (from .5mm over to .75). I was initially going to buy some NPR pistons, but decided to just let the shop order some aftermarkets, and have them swap over the connecting rods. I know I sound like a horrible person for having no idea what brand they bought (there looks to be a logo on the inside of the piston skirt that is a sort of S inside a circle), but that's the sad reality. As far as I know, the old pistons were from a 2G turbo - the stampings on them were 63DT-F1 - whereas the current ones just say 63D. So from what I've gathered on my own, these are 1G NT pistons (or did 2G NT also have this stamping?), and therefore 9:1 CR. Since I was planning on having 2G T pistons anyways, is an additional .5 in CR a huge deal? My intention is to have a mostly stock daily driver, but maybe push it up to 250hp some time down the road. This project has already been one hassle after another, and I just want to put the damn thing back together already, but of course, I also don't want to have to go through all this crap again in a couple months. So what I want to know is, is using NT pistons a bad idea, or should it be safe with the stock tune, and maybe reduced boost? What about down the road if I want to get ~250hp? I don't really want to have to go back to the machine shop, but if using these pistons is just asking for trouble, then I certainly will.
Cheers
6 bolt rods are 6 bolt rods whether it's turbo or not. 7 bolt rods are the same whether 1g or 2g. Obviously there was no 2g 4g63 NT so NT 7 bolts are limited to years 93-94. Spyder may count but it isn't a point of this discussion.
Mostly true, but I wanted to correct this logic. In 99 you could get a 4g63 NA Eclipse as kind of a good bye to the motor. However they are rare, in all honesty it's one of my most desired DSMs.
Ok, awesome. That's the route I'll go then. Thanks for the info.
Apparently I looked over the part on my receipt that specified that the pistons are NPR, which is the brand I would have bought on my own. I'm gonna go back, but I'll make sure to tell them to order 93-94 turbo pistons specifically this time.
RE piston rings - is it safe to assume that they're different between 93-94 turbo pistons, and 93+ non-turbo? I tried searching around, but I couldn't find a consensus.
I could be wrong but I'm pretty sure that all EDM non turbo 2g's came with a NA 4g63.
