URGENT: Anyone that has switched their Fuel Filter
Bubba9110
70
Apr 13, 2010
Madras, Oregon
Can someone that has switched their fuel filter out no a 2g talon please text/call me ASAP? I need to get this changed very soon because I need my car to be running. Just PM me for my number. Thanks :)
If it's like the 1g, it's a 19mm for the banjo on top and a 14mm on the line at the bottom of the filter
+1 and typically pretty easy to do since those fitting dont typically see much weather and dont get rusted.
There is a mount for it also and that is a 13mm to pull the filter and mount off. Then there is the part that holds the filter in the mount which is a 10mm.
Ok thanks. That's the main problem I'm having is getting the lines off of it. I can't find the right wrench to use but I'll try those two.
You should use a flare nut wrench instead of a regular open end. On my filter those lines were damn hard to get off. The old filter began to crush before the fittings broke free.
odd. I changed the filter on the 1990 gsx i just got recently. Doing all the maintenance. And the filter was stock with 182k on the od. Came off pretty easy but, I suppose it depends on the location and weather you live in.
