has anyone made their own water injection kit
da kang3
190
Mar 26, 2005
ft hood, Texas
im just wonderin if there is anyone here that has made their own water/alcohol injection kit? i know a guy that has made his own kit but is working the kinks out of it. and it's for a honda not a dsm. so im wondering if anyone here would be able to enlighten me on how to make my own kit
I wouldn't mind hearing this either. I just went to hot import nights in chicago and saw a hella nice IS300 turbo'd with alc. injection. He said that he got really huge gains.
I made my own kit by following the links posted and others. I haven't had a single issue with it and not even a "kink" to work out. As long as you read as much as you can before tackling it job, you'll be fine and will most likely save a lot of money compared to buying a pre-fab kit. Good luck.
My tip for you is to use a pressure gauge ($8 at your local hardware store) and a water hammer aka pressure accumulator (~$20 on e-bay)
and can any of you answer this question for me? is this safe for my stock valves and stock everything else also? last question i have. i hope this helps anyone else who was thinking of doin this also, cause i know i am. will give me something to do while im waiting for my new crank and clutch to be broken in
  • Wanted 6 bolt NT water pipe
    • chrisman287
