Upper Ball Joint Compatibility
twinkiemobile
107
Jul 21, 2004
Tolleson, Arizona
Hello Everyone,
First off I am having some noises coming from one of the ball joints on the driver's side of my 95 Eclipse GSX. Since the recall will replace the lowers, I would like to replace the upper of the driver's side only to see if that will solve the problem.
Anyway, I was wondering if anyone knew what other cars i can draw the upper ball joint from. I know that I can get it off of other GSX's and TSi's but can I also get it from RS and GS Eclipses and Talons? Can I get it off of a 1g or am I restricted to scraping parts from 2g's? Thanks for any help
- Jose
Um, asking whether you can use the upper front balljoint off a 1G is kind of silly. Someday you will realize why, smack your forehead, and say "doh!"
You can use the upper arm from any 2G.
- Jtoby
Thanks a lot, I will go check out a 1g and see what you're talking about. hahaha.
- Jose
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
