97redgsx
- 61
- 0
- Nov 8, 2006
Medford,
Massachusetts
ok so i bought a 20g over the winter because i found a really good deal. it was a little bigger than i wanted to go but the price was right. anyways, now im getting my tranny back from pruven performance next week and i am going to be driving the car...finally.
now i have a few questions regarding my new turbo:
what boost levels can i run with stock fuel?
are there any "cheap" fuel upgrades that i could stick on until i get the proper stuff just to run a couple extra psi?
i have been searching the forums for a while now on the subject and i haven't seen much on the 20g, more the t28 and 16g. however i have seen a few tims, from reliable sources, that a bigger turbo will "blow away" a t25 at 16psi at only 13-14psi.... i don't mean to sound like an idiot but how isn't 15psi the same no matter what turbo pushed it?
so far my supporting mods are:
fully rebuilt engine(stripped it to the block and replaced every bearing/seal, as well as removed the balance shafts)
tial 38mm external wastegate
MBC
1st gen BOV(crushed)
thanks for all your help guys
MBC
. . .It's just not true. Surge is more detrimental to performance than the other end of the map WRT compressor choice. The turbines efficiency DOES NOT alter the efficiency map of the compressor. It does something far more important. Compressor efficiency is a good indicator of turbo rpm which is helpful in determining whethor or not the turbo will blow up at a given boost level and a given volume flow demand from the engine. As no turbo manufacturer would completely off-balance the flow capabilities of a turbine and compressor combination (hybrid or not). The key here is simply volume demand. If a 2.0L engine w. 272s demands 35 lb/min from a small 16G at 20 psi then it demands the same from a 20g at 20 psi. Looking at the comressor map, where does the efficiency lie between the two. Further. . . here's the calculations to get to volume flow for a simple turbo/intercooler setup:
