DSMunknown
- 4,108
- 44
- Sep 16, 2004
Worcester,
Massachusetts
If anyone has looked through this thread, they would know I have all four Evo 8 calipers and Evo 9 rotors lying around the house. These will be a phenomenal upgrade from the puny GST combo.
I also have to purchase the steering knuckles that will accomodate for these new calipers.
The "problem" is that now I have to look for some rims and tires. The tire option is pretty obvious to me: Kumho MX rubber. However, I am very picky on the rim choice. If I had the money, I would have custom-made 17x8.5 inch rims that look exactly like the OEM 5-spoke 16" rims I have right now. I was thinking about doing this a couple years ago, but have completely abandoned that idea altogether. It would be sick, but I definitely don't have the money to waste on that sort of thing.
So what comes with bigger rims? Wheel/fender gap.
Of course, I already have that, but it'll look even worse without modifying the suspension.
Do you see where this is going?
I know I'm not the only one. People upgrade to DSMLink, then injectors, then turbos and front mounts, and so on and so fourth.
I'm just a little pissed off because a little brake upgrade is going to transform into almost revamping the entire suspension system... on a GST no less!
This is what I get for trying to save a few bucks.
I also have to purchase the steering knuckles that will accomodate for these new calipers. The "problem" is that now I have to look for some rims and tires. The tire option is pretty obvious to me: Kumho MX rubber. However, I am very picky on the rim choice. If I had the money, I would have custom-made 17x8.5 inch rims that look exactly like the OEM 5-spoke 16" rims I have right now. I was thinking about doing this a couple years ago, but have completely abandoned that idea altogether. It would be sick, but I definitely don't have the money to waste on that sort of thing.
Of course, I already have that, but it'll look even worse without modifying the suspension. Do you see where this is going?
good luck
