For Sale Upgraded evo brembos
FIBA M - EC17PSE
Supporting Vendor
6,753
5,159
Nov 1, 2008
Orlando, Florida
I have some evo 9 front calipers up for sale but not regular ones,
I swapped out the alloy pistons for racing brakes racing pistons and high temp seals great for those looking for better protection against fluid boil, i also installed new stainless bleed nipples and made 2 new cross over pipes that wont corrode like the oem ones do since its made from copper/nickel. Stainless pistons will protect against brake fade from over heating the fluid. They also will not corrode or crack like alloy pistons do over many years or if your racing. The high temp seals are rated to a higher degree so wont be an issue but you must not get brake fluid on them or they perish! It states this on the racing brakes site!
They were home painted by myself with vht branded caliper paint and soda blasted to keep the protective black under coating on, everything was then baked but the paint is old and chipping so could use a repaint or use them as they are as i did,
Recently took them off for a caliper swap so they 100% work as i been using them for the last few years exactly the same way! You can install these bleed it all and just drive with them and no issues.
$600 shipped.
  • For sale 1g 91-94 ignition coil
    91-94 ignition coil. Good condition. Have the weather pack that plugs into it and the stock...
  • Wanted valve body for 1GA AWD.
    Looking for a valve body for 1GA AWD.
    • kaanevrensel
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
