Upgrade O2 housing on a 13g? Worth it?
V8HAHA
257
Jul 5, 2004
Seattle, Washington
I am trying to figure out if it is worth the time to weld up an O2 eliminator dp, or a normal one. Will a 2.5" O2 housing make a noticable difference over a stock unit? Ported stock unit? This is with full 3" exhaust.
If you ever plan on upgrading to another mitsu turbo I say go for it. The difference will be minimal but every little bit helps:thumb:
WTF Ive been on here for 4 days straight looking to see if a 2g 02 housing will fit on a 1g 13g no one has been able to help me out. and i dont want to pull the old one off just to see it dosnt fitWTF
Since both generations use a mitsubishi exhaust side, I couldn't see any reason why it shouldn't bolt right up.
see this is what i get! i get people that dont know! i have a 13g auto not a 14b manual all im asking is if the 13b in a 1g will bolt up to a 2g o2 housing. plain and simple
I was giving you the answer to your question, not guessing. The exhaust side on the 14b, 13g, and t-25 are all the same flange pattern. So there is absolutely no reason it wouldn't bolt up.
yes, it will bolt up.
I'd say go for it too. When you upgrade to another (mitsu) turbo, youll still be able to use the same o2 housing
